External TV/tuner box for PC/HD recordings
Discussion in 'TVs' started by mandm, Sep 17, 2005.
  1. mandm
    mandm
    Sep 14, 2005
    316
    Hampshire
    +7
    hi there
    A newbie type question? :lease:
    I would like to record satellite channels delivered to our residence via RF/Terrestrial cable; therefore all the channels are viewable only via flicking through TV channels.
    Although the above setup is fine but I cannot record programes to my PVR (personal video recorder – Topfield).
    I believe I can overcome the problem by acquiring an additional hardware (TV/tuner type box) and record channels directly on my PC's hard disk using the USB2.0 port. I would like to use the schedule recoding, time shifting etc. I would prefer the box to have hardware compression to avoid overloading my PC.
    I would like to know what you guys think of my solution and if you could recommend any hardware/TV box?
    I hope to hear from you soon.
    Many thnaks in advnace
  2. mandm
    mandm
    Sep 14, 2005
    316
    Hampshire
    +7
    16 views and no response so far, guess must have asked a difficult question?
    :oops:
  3. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    978
    Coventry
    +33
    :) Good STB is the Sony. Sorry can't help you but someone will soon...
  4. mandm
    mandm
    Sep 14, 2005
    316
    Hampshire
    +7
    thanks for your response m8, yep i hope someone would response, BTW i am not sure if the Sony STB would allow me to record progs on my PC's HD!
    I need/want to do recordings on my PC so i can watch the progs at my leisure
    :smashin:
  5. mandm
    mandm
    Sep 14, 2005
    316
    Hampshire
    +7
    40 views and and no positive lead yet, guys have i put this question in the wrong forum, perhaps the admin can clarify this?
  6. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    978
    Coventry
    +33
    I'm no techy but I think you need to either connect a normal freeview STB to your computer via your normal tv tuner card. Or, you can get something like the 'Twinhan DTV Alpha'...Its a digital tv tuner card that plugs into your USB port. You can then use your PC as a PVR with the right programs.
    Any help????
  7. mandm
    mandm
    Sep 14, 2005
    316
    Hampshire
    +7
    chriszzzzzz m8 thanks for your help, i agree i need a digital tv tuner (ideally external) card/box that plugs into USB port and that would allow me to use PC as a PVR.
    As i don't know much about 'Twinhan DTV Alpha' so will do a google, but if it is a card then it would probably goes in one of the PCI slot, but if it's an external box then likely to go in the USB port.
    will let u know what i find about 'Twinhan DTV Alpha'!
    cheers
