External Storage?
Discussion in 'Desktop & Laptop Computers Forum' started by General Skanky, Feb 24, 2003.
  1. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    Is it possible to buy a caddy for a normal pc ide HDD to use as an external usb/firewire hdd?
    I'm sure I saw a caddy like that a little while ago, but can only find laptop sized caddies.:confused:
  2. Kramer
    Kramer
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    Thanks.
    I was hoping for something a touch cheaper.
  4. Kronin
    Kronin
    Try http://www.span.com/system/index.htm , good company (their website doesnt look too appealing I know but Ive dealt with them before and they were very good).
    Just go to the firewire or usb category and look at the desktop cases - I thought the "IceCube" looked quite nice :)
    Theyre cheaper than most places but firewire and usb caddys as a rule are around the £100 mark.
    HTH.
  5. HMHB
    HMHB
    Nov 11, 2001
    26,459
    Nottinghamshire
    +5,077
    I've made my own - bought the external housing and then put in an 80GB HDD. I bought it on-line from a company in Leeds but can't find their details. I will look for the invoice if you need further information
  6. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I saw one at the ISP we use - it was only USB (no Firewire), but I think it was USB2. They said it was about £50, but I didn't get the name of the darn thing. I'll see if I can find out more...
  7. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Right, what about these:
    http://www.vipower.com
    Basically, you can buy a caddy with power supply, then a "smartcable" to go with it which converts IDE to USB2, Firewire or PCMCIA (depending on the cable).
    They do 5.25" Caddys, as well as others.
    Just seen they do a 3.5" jobby complete for £40 - click here for a link to a supplier in the UK. Don't know if these are the cheapest people, just the first supplier Google came up with.
    HTH
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    Ideal! Thanks. Typical, I aways use a search engine but didn't this time.:suicide:
  9. nathan_silly
    nathan_silly
    I was looking for one as well, cheers! I'll move my 60GB from my desktop to the box, and buy a 200GB for my desktop
    Nathan
  10. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    High Wycombe, Bucks, UK
    +59
  11. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I fancy one to put the DVDRom into, and run the power, reset and LEDs up to it as well. Then I could bury the main box somewhere, and just have a nice little box on my desktop. I guess a USB port up there would be good too.
    Looks like another tinkering project on the way....
  12. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
