External Speakers for Toshiba 32wd98B
Discussion in 'Home Cinema Speakers' started by andymon, Jan 9, 2001.
  1. andymon
    andymon
    Hi [​IMG]
    How can i make better use of my Toshiba 32WD98B in the way of adding more of booming cinematic sound. I have tried adding external speakers but they don't seem to make much difference, I also cannot see where I can plug an external Sub Woofer in which I believe would make a difference.
    The speakers that are built in do not seem powerful enough. Will I need a seperate amp and speaker set???
    thanks
    Andrew
