External Speakers for DD5.1 t.v?
Discussion in 'Home Cinema Speakers' started by StB, Mar 11, 2001.
  1. StB
    StB
    Can anyone recommend external front speakers and a sub for the Toshiba ZD08B? I read the review on 'Home Cinema', in which it states to buy extra speakers.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,601
    7
    167
    Birmingham, UK
    +10,463
    To be honest, the best route would be to buy a separate amp and speaker system. The whole lot doesn't have to cost very much (e.g. Yamaha A5 and Eltax symphonies) and will sound 100 times better than the telly.
