Question external speakers, and how?
Discussion in 'OLED TVs Forum' started by Cas71, Dec 27, 2016.
Tags:
  1. Cas71
    Cas71
    Dec 10, 2015
    Sevenoaks
    +3
    Hi I have an LG 930, and I am thinking of using external bookshelf speakers (good quality).
    Can anyone help, as I am currently considering using the headphone audio out to an amp, which would then power the speakers.
    I am trying to achieve a superior sound quality (wired), but i'm not sure if this route is the best way to go.
    Many thanks.
    Could someone explain what privileges you need for the classified section, I don't appear to have enough?
  2. SALVETA
    SALVETA
    Oct 18, 2015
    47
    11
    Sweden
    +8
    You don't have optical or HDMI on your amp then?
  3. Cas71
    Cas71
    Dec 10, 2015
    Sevenoaks
    +3
    I am trying to achieve good sound on a small budget, therefor the speakers (Q Acoustics) and amp (?) would be second hand, but i'll have a look.
    Thanks Salveta
