external HD
Discussion in 'Desktop & Laptop Computers Forum' started by malsat, Jan 29, 2005.
  1. malsat
    malsat
    Sep 13, 2004
    276
    +10
    ive just got a usb external hd,and i want to use it for my desktop running xphome,also my lappie running win98se.
    when i connect to desktop its ok
    when i connect to lappie i need to format it,if i do will it still work with my desktop?
    i want to transfer data between them.
    thanks
  2. Kahless725
    Kahless725
    Win98 does not support the NTFS so format it FAT32 using Win98 and both should read it. Weird that this should show up on a USB2 device.
  3. malsat
    malsat
    Sep 13, 2004
    276
    +10
    thanks
    if my xp dosent recognise it what should i do?
  4. Kahless725
    Kahless725
    Try it first I am 95% sure it will
