External harddrives?
Discussion in 'Desktop & Laptop Computers Forum' started by G1OSE, Nov 25, 2004.
  1. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    ok quick question if i was to buy a laptop with usb 1.1 and plug into it an external hard drive to run dvd's of as in laptop screen and dvd player type set up but instead of dvd player a harddrive with dvd recorded to will it play smoothly or jumpy also can a laptop power the drive the laptop has usb1.1 and pcmcia slot if that makes any better connection
    chars!
    D
  2. Synchro
    Synchro
    Nov 14, 2004
    4,138
    Chester
    +569
    In english? Thats all one sentence for *$%£&£%^&'s sake!
    I tried to get my head around it but failed :(
  3. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    Ok quick question, if i was to buy a laptop with usb 1.1 and plug into it an external hard drive to run dvd's, as in laptop screen and dvd player type set up but instead of dvd player a hard drive with dvd recorded to it, will it play smoothly or jumpy. Also can a laptop power the drive? The laptop has usb1.1 and pcmcia slot if that makes any better connection
    chars!
    D
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    In theory USB 1.1 can transfer at 12Mb/sec, which is somewhat more than the 1x speed of a DVD so you should be okay.
  5. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    so if i dont actually run a dvd but instead a dvd that i have stored on a hard drive or even like some crappy video that i have made and stored on the hard drive it should not be jerky is that right?
    reason im asking is it could be a costly move if wrong
    EDIT
    Also does it make any difference if i try and power the drive from the usb or would it be better on mains?
    cheers
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I doubt you'll get an external hard disk powered from the USB port, I've certainly never seen one.
    As for how it'll perform, I can only go on the transfer rate of the USB 1.1 port and the fact that 1x DVD speed is something between 1 and 2 Mb/sec, I've never tried playing off a hard disk on USB 1.1, only ever used 2.0.
  7. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    There are usb powered drives out there, the freecom fhd2-pro (or something like that) for example.
    However in my recent quest for one the few that were usb powered tended to be USB2 and not compatible with usb1.1.
    Still you may find one out there
  8. cowtipper
    cowtipper
    Jan 29, 2004
    164
    19
    i have got a 40gb usb 1.1\2 drive thats pulls power from usb but it does have 2 usb connections for when you are hammering the disk.
    the video will play back fine i think dvd is processed at 4.8 mbps
    I have just tested and it ran without a problem but my desktop is a 2.2 with 1gb of ram
  9. Epithet
    Epithet
    Have you considered a firewire card for your laptop? I use independently powered external drives connected to the firewire port of my desktop and they produce seamless playback on PowerDVD 5.
    Tony M
  10. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    well i think the firewire option for the laptop would be very costly so no
    as to the usb drive using 2 usb ports is that all the time and if run from one how does it perform also was that on a desktop or laptop that it used 2 mine will have 2 ports and dont mind using both if needs be
    could you please give me the model and price or link to the usb drive you have thanks
  11. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    If you're looking for decent external drives,the Maxtor ones are fine.....I have a couple of these,incl a 300Gb drive.
    What I would recommend though is getting a Firewire or USB2 card for your laptop,as USB1 is way too slow for video,and stuttering/pausing was common when I tried that on mine.
    Firewire card for a PCMCIA/Cardbus equipped laptop...about £25-35.
  12. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Out of interest, what external hard drives would you guys recommend? I have a big one in mind!!!!!!!!!!300Gb
    regards
    Darren
  13. marcm
    marcm
    Darren
    I have just got a Maxtor 250gb £136inc VAT from EBuyer, I believe they have a 300gb version also. This works well for me, but I use it from a desktop so can't compare with laptop. It runs from USB2 or firewire.
  14. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    I build my own . The external cases come in a variety of types and even styles. Use a normal internal HD of whatever size you wish.
  15. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    I have the 300Gb one here....nicely made,very quiet,and works without any fuss,and used both on my desktop and laptop via a Firewire Cardbus card....recommended.
