External Hard Drive
Discussion in 'Computer Components' started by ColdKilla, Nov 4, 2005.
  1. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    I have a laptop which I am confident can run 720p HD but the problem is it doesn't have adequate hard drive space - Is there such a thing as an external hard drive I can attach to my sony laptop that will increase the capacity but retain the transfer rates so I dont get a bottleneck with the data through to the pc?
    CK
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    You can get a USB2 hard drive enclosure, and stick a 7200RPM PC hard drive in there...Enclosure around £20-30, 200GB Hard Drive around £70...or you can just get an external usb hard drive from western digital or maxtor..
    Western Digital
    2nd one from bottom should do...
    Maxtor
    3rd from from top
  3. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    USB2 Transfer rates are adequate for HD?
    CK
  4. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    yes...
  5. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,242
    Which Sony do you have? a lot of them come with FW interfaces these days, which would certainly do the job... I'm not sure on USB TBH..
    If USB isn't suitable, you can always get a FW PCMCIA card for about £30 (and that's PC world prices, so should be much cheaper..)
  6. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    If oyu want Firewire best option is a Lacie Drive...there supppost to be fast and reliable, it's what the pro's use for editing/storage...
  7. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    Not sure re firewire it is a PCG-GRT715M P4 2.8 Ghz??
    CK
  8. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
    not sure on that one myself...
    have a look in device manager for an IIE1394 bus host controller
    Is there one there?
  9. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    Yep got that!
    So I have firewire and I never even knew it???
    How do I connect a firewire drive then do I need other bits?
    CK
  10. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
    well... it 's supported on the Mboard, just a case of if the connector is there now..
    there should one I'd guess...
    It looks much like a B and is about 5mm in size.... that's a 4pin FW connector.
    If you've got one of these, you're in business.
    Most FW drives come with both full-size and mini FW cables, so you can just plug straight in. :thumbsup:
  11. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    For the Western Digital WDXB2500JBRNU Dual Option 250GB External Firewire/USB 2.0 Hard Drive
    1394a
    Serial Bus Transfer Rate (1394a) 400 Mbits/s (Max)
    USB 2.0
    Serial Bus Transfer Rate (USB 2.0) 480 Mbits/s (Max)
    So maybe USB2 is better?
    CK
  12. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    Yeah sony call firewire iLink and I do have a little B on the side! But based on the above maybe USB2 would be better?
    CK
  13. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
  14. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    FireWire800 is fastest ;)
  15. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    And is there such a thing as a firewire 800 drive (if that is what it is called) and if so where do I get one of them?
  16. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
    You're much better with FW..
    With FW you really do get that throughput, with USB the 480 figure is mostly imaginary... ;)
    Most External drives such as the WD's, and the Maxtor One-Touch, come with both interfaces anyway, so give both a go and see which you prefer...
    - I know the answer already from doing so myself...
    I have 6 of the maxtor 300GB drives now, they're cheap enough.. and almost indestructible in my 'gravity based' resilience tests so far :rolleyes:
    1 goes everywhere with me in the laptop case, one lives in my car serving up MP3's... 4 attached to my HTPC serving up all my music/DVDs.
    I'd be lost without them in all honesty... I can't imagine having to 'install' hard drives these days....getting lazy in my old age...:D
  17. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    I wonder if I need to spend the extra on a firewire 800 drive or whether USB2 will cut it?
    CK
  18. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
    forget about FW800, you'd need a FW800 add-in card for that..
    FW is MILES better bet than USB2.... trust me on that one. ;)
    FW800 is really just a joke played on the unwary buyer by hardware manufacturers.... I can't think of any real world situation where you'd need anywhere near that level of throughput..
    You only need 25mbps for a HD movie.... just how many are you planning on watching at once? :D
  19. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    Lacie make some excellent firewire 800 drives - their triple interface (usb 2, firewire 400 & 800) ones are superb.
    Supposedly despite USB 2 having a theoretical faster transfer rate than firewire 400 you'll get a better transfer speed with firewire and it's less processor intensive. Most of the folks I know doing video and 3d work use firewire over usb.
  20. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
  21. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
    I'd say betwen those two the maxtor looks the better option, but only because I have more faith in maxtor HDs than WD...
    Apart from that. they're virtually identical.... flip a coin maybe? :D
    - arrgghhhh.... I've just noticed the 300GB 'network drive'... and I thought my upgradeitis was just a painful memory...:rolleyes: :D :devil: :rolleyes:
  22. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    Yeah i've just noticed that. Good price too - cheaper than the Lacie network drives (have a250gb one here) and cheaper than the 1TB Buffalo network drive we've just taken delivery of... very tempting :devil:
  23. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    One on order :)
    Cheers guys!
    CK
