External Hard drive
Discussion in 'Computer Components' started by niccam, Jul 3, 2005.
  1. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Hi could someone please point me in the right direction on when I have powered up my external hard drive ( usb connection ) do I have to do the action off REMOVE SAFETY HARDWEAR before I switch off or is that only if I want to pull out the USB lead while the computer is still running? Thanks for any info.
  2. Werner
    Werner
    only if you want to pull out the lead while the computer is still running....
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    I use an external DVD writer and pull out the firewire lead a lot with them on.
    No problems here.
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    I just turn my hard disk on and off when required. I don't bother with the safely remove hardware business. It appears in "my computer" and disappears when turned off.
  5. Skunkpipe
    Skunkpipe
    It's best to remove a HDD safely - horrible things can happen if you're half way through a write to it
  6. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    Who would remove it during a write?
  7. Skunkpipe
    Skunkpipe
    who knows what windoze is doing to it
  8. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Thanks everybody I think the correct way is if you pull the firewire cable outwhile running you need to to remove safety hardwear correctly as pointed out by Werner .
  9. Maff et1
    Maff et1
    Windows uses lazy write caching to hard disks, there is no way of knowing if those caches are flushed without doing 'safely remove hardware'. Mass storage devices are the only ones where you need to do this (hdd and memory sticks/thumb drives).
    I did manage to corrupt my memory stick once by pulling it out a good couple of minutes after I'd finished writing to it.
    Shutting down the machine will also cause it to flush the caches so you don't need to 'safely remove hardware' before a shut down (as long as you turn off the PC before turning off the external drive)
