External Hard Drive
aet3
Hi Folks
I want to buy an External Hard Drive for my wife, so she can backup all her files/photos etc.
She has a Toshiba Laptop running Vista Ultimate.
I propose a 500GB external drive or minimum 300GB.
Any suggestions on which one to buy ??
I assume she just attaches it to her Laptop through the USB connection to transfer the files.
Is this done by just copy/paste or dragging to backup files ??
Any comments or help would be greatly appreciated.
Cheers.
Well, there are two different types of External HD's.
You have got the External Desktop HDD which plugs into the mains & the External Portable HDD which doesn't.
I have always used WD = Western Digital as I have never ran into any problems with them.
Here are two I would recommend:
Desktop HDD - Western Digital My Book Essential 500GB External Hard Drive Hi Speed USB - Retail - Ebuyer
Portable HDD - Western Digital My Passport Essential 500GB Portable Hard Drive Hi Speed USB - Retail - Ebuyer
Hope that clears a few things up :D
oldnewbie
I would agree with this, I have been using the one in the first link for some time (over a year) and have had no problems whatsoever :smashin:
aet3
Hi - Thank You for your responses, it is greatly appreciated.
I think the Portable route is the way I need to go, as I want minimum cables across the room !!!!
The recommended web site looks good.
Iccz
Ebuyer is a brilliant site :thumbsup:
With regards to the portable drive, it will be a little slower than the other as it is powered by USB, so if you need to do a lot of copying of big files and want speed then go for the other.
aet3
Thank for the comment re speed.
But, I will still go with the portable, because as I said I do not wany cables across the floor.
After the initial first very large backup, the files should be a reasonable size, also, as we are both retired:
TIME IS OURS !!!!!!!
Cheers.
aet3
Sorry to come back again Folks
But - I read a review of the drive I am contemplating getting ( The 500GB Portable in above threads), and the writer states the problem is that it has a USB Micro Port instead of the normal USB Mini Port.
Is this problematic ??
I assume it will still fit the standard USB Ports on her Laptop ??
As you see we are a bit "green" to all this computering !!!!
Cheers.
benzy
My girlfriend brought one via ebuyer which is a site i useally trust and upon seeing this hard drive was impressed as all it need was a USB wire to power it and transfter files. but it diddnt last long and unable to transfer files. told her to format but she doesnt want to lose these files...i doubt i helped
aet3
Did you discover what caused the error ??
No doubt there are satisfied customer with the same drive having no problems (I hope !!!!).
Cheers.
aet3
But - I read a review of the drive I am contemplating getting ( The 500GB Portable in above threads), and one review writer states the problem is that it has a USB Micro Port instead of the normal USB Mini Port.
I assume it will still fit the standard USB Ports on her Laptop, as this is all she has ??
oldnewbie
This is not a problem at all because it comes with a usb cable that will fit the small usb on the hardrive and on the other end of the cable it will be a standard fit, So it will plug into any pc or laptop :thumbsup:
