External Hard Drive - High Pitch Whine
Discussion in 'Computer Components' started by Batch, Sep 5, 2007.
  1. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    University: Lancaster, Home: Cambridgeshire
    +200
    Over te past few days my Western Digital hard drive has been whining every 15 or so minutes for about 3-5 seconds. Should i be worried?
    I've had the HDD for abou 10 months, and dropped it about 1ft about 8 months ago but thought nothing of it as it's been fine since.
    I am currently downloading a large file directly to the HDD, could this be the cause of the probem?, although i don't think so.
    Any help?
  2. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    noone able to help?
  3. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    ok, so i've just ordered a Seagate FREEAGENT PRO 500GB to bakc it up on. Phoned support they said it didn't sound good.
  4. Vandiesel
    Vandiesel
    Jun 6, 2006
    1,470
    +40
    Clicking is usually what you usually associate with an on the way out drive. I had a WD drive that had a high pitched whine, but it was constant
  5. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    This doesn't really sound like clicking, it is definatle a white and now appears to be random. I've got a replacement on the way.
  6. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Get a freecom drive they are fanless.
  7. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,869
    Londoner living in Bahrain
    +140
    My WD twin raptors always have a very high pitch whine and have never failed .... ever :thumbsup:
    That said, you should always have a backup .... learnt that the hard way :mad: (my data disks got wiped by ... ummm ..... "user" error :rotfl:)
