External hard drive (formatted to FAT32) not appearing??
bozwellox
Hi guys,
I have an external 300gb USB Seagate drive and I'm hoping to use it with my PS3.
I have read the usual instructions regarding formatting as FAT32 etc, the drive is already FAT32 (from the factory) and I have created the folder structure:
VIDEO
MUSIC
GAME
But when I connect the drive to the PS3 by USB it does not appear at all. Yet when I plug my 4gb Kingston pen drive it picks it up straight away.
Any suggestions? Like I say - it is already in FAT32 format so as far as I'm aware it should just work.
Thanks in advance for any help! :)
bozwellox
Solved it! Very weird, although it was formatted as FAT32 there must have been something not quite right with the formatting. I reformatted it as NTFS, then once it had finished used fat32format.exe to format it BACK to FAT32 again, and hey presto it worked.
I've found a few other posts on the web from people having the same problem using a Seagate external drive with the PS3 so must be something to do with the way they are formatted??
Anyway, I'm glad it's sorted!
Johnboy_1975
Got exactly the same problem. Is your drive the grey almost triangular one? Its gonna be a right pain sorting out what to keep before formating it as I only have about 50gb free on my laptop, and there's 240gb on there. :suicide:
Still, time for a spring clean :hiya:
biccys
I had the EXACT same problem. I didn't want to format the external hdd either, so I used my phone to get the backups of games I wanted then just bought a ruddy great big new hdd for the PS3!!
Glad you got it sorted though. Seems strange that "FAT32" in Seagate world doesn't appear to mean "FAT32" in everyone elses?!
potnoodles
I recommend Seagate software - Discwizard - to format Seagate (and Maxtor ) drives .
Method
Delete all existing partitions
Create a new one and set the format to fat32
Seagate Technology - DiscWizard
