External Hard disk drives
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Eee-Tee, Feb 2, 2003.
  1. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    I realise this is slightly 'off topic' but it does concern camcorders and edititing.
    Due to the ammount of storage space Digital Video needs, i'm thinking of enlarging my hard disk. Instead of buying an internal one, i've thought about an external one. Does anyone know much about these? eg what sizes (Gb) you can buy them in?
    Am i right in saying that they are connected by firewire?
    Also, does anyone know of online shops that would sell these cheeper than places like Pc world /ect.?
    Thanks in advance.
  2. scott69
    scott69
    I've also been considering extra storage for my dv footage.
    It looks like internal hard drives are much cheaper than external.
    I'm going to add a second internal drive which costs approx. £1 per GB. I've not decided between 80 or 120 GB yet.
    If you really want an external drive check out the Maxtor drives at www.microdirect.co.uk which use USB or Firewire connection.
  3. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Scott- i agree that external HDD are v. expensive, the only reason why i might opt for them insrtead of in internal one is that they're easier to install- you just plug in ( as far as i know)
    Do you Know how to install fresh internal memory- could you (simply ) explain?
    What i am not sure about is how installing more would affect every thing else on my PC- would it all work as before but with the advantage if more storage space, or would it be necessary to alter any thing?:confused:
  4. scott69
    scott69
    I'm not a computer expert. I have installed a firewire card and added more RAM to my PC, but thats it !
    I'm going to have a go adding a second hard drive sometime soon. If you want to know more about it just type in "adding a second hard drive" into any search engine and you will find tutorials with pictures. If you're not sure you could take your PC to a local PC store and let them install it. It might still be cheaper than buying an external drive !?
  5. Duncan Craig
    Duncan Craig
    Internal Hard drives are cheaper, more reliable, and a lot faster to transfer data. If you have the spare slots, fill them up, it's really, really easy.
    Go for IBM deskstar 7200 rpm.
    You can get various capacities 20,30,60, up to around 120GB are fairly usual. Try dabs.com.
    You can get 60GB for around £60.
    I've got several external Firewire drives, but only because I need them for Final Cut Pro on my laptop.
    I would avoid Maxtor, I bought several and they all dropped frames when working with DV footage, which demands very high bitrates for firewire connections. I've got Lacie drives and they are superb.
    Internally connected drives will easily manage DV footage. You should be able to install another drive in a couple of minutes, and it won't affect you computer at all. It will just appear as another usable drive.
    Lots of benefits, just remember to keep things tidy cos you'll soon fill it up with crap otherwise.
  6. Adlopa
    Adlopa
    Nov 25, 2002
    74
    External hard drives cost at least twice as much as the same capacity internal drive and are available from a number of manufacturers. Look for a USB2 or FireWire connection though -- USB (USB 1.1, technically speaking) is far too slow. If your PC isn't relatively new, you will probably need to add a FireWire or USB2 expansion card inside too but this is pretty simple.
    FireWire/USB2 hard drives work as soon as they're plugged in. I've used the Maxtor models and they seem fine to me but I have no experience with them for video editing.
    Providing your PC has a free 3.5in drive bay (it almost certainly will have), an internal hard drive is a much better bet -- look for a speedier 7200rpm model rather than 5400rpm. 120Gb drives cost around £100 now, which is a bargain. Fitting one is very straightforward and if you buy a boxed consumer drive (rather than a cheaper brown box OEM model), you'll get full instructions. Otherwise, I'm sure a net search will turn up some useful info or failing that, try searching one of the computer magazine sites, such as Computeractive (good for newbies ).
    And finally... IBM hard drives have a very bad reputation but I can only say good things about Maxtor and Seagate.
  7. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Thanks for your advice- its given me something to think about
    Just to recap- Intenal as opposed to external
    IBM, Maxtor or Seagate
    7200rpm
    Anything else i should know?
    thanks:smashin:
  8. Duncan Craig
    Duncan Craig
    You'll get away with 5400 rpm drives if you can find a good deal for one.
  9. CW1000
    CW1000
    Yes AVOID IBM hard drives at all costs (I was unlucky to own one of the dodgy ones)
    Go for Western Digital if you want Performance
    Go for Seagate if you want a near silent drive
    Go for Maxtor for an inbetween drive
  10. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    As Duncan Craig mentioned Lacie are very good - i've used quite a few and all have been reliable. They aren't the cheapest tho.
    I'm currently using a firewire version of this from Smartdisk and its fantastic for such a tiny drive - but if you dont need anything portable they also do standard sizes They also do a 800Mbit firewire drive with 200gigs of space.
  11. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Can anyone advise an online shop that sells good value (internal0 hard drives ?;)
  12. scott69
    scott69
    You will struggle to find a cheaper site than www.dabs.com
    I've lookad at loads of sites and after delivery etc dabs seems to be the cheapest. Sometimes if they have deals on www.ebuyer.com can be almost as good. If anyone knows of a cheaper site please tell !
  13. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Cheers Scott- i'll take a look
  14. swilt
    swilt
    Try scan.co.uk.
    They are about the easiest thing in a PC to fit and always work so don't worry. If you are able to put it off the same cable that your current hard disk is connected to, make sure it is set as a slave. There is a little pin on the hard drive. If not just plug it directly into the spare ide port.
  15. EvilMudge
    EvilMudge
    Something that really comes into it's own when capturing video and then editing it is a RAID array. If anyone's interested I'll post a complete guide to setting one up (should be cheaper than an external hard drive!).
  16. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    I've had a look at Dabs, and they dont seem badly priced.
    Could some one clarify a couple of things?
    On the search window, it has an option for 'seek time' Can someone explain what this means, and if it is impeotant. if so, what value would be best?.
    as well as the 3 makes recommeded, they also sell others-
    HP
    Compaq
    IBM
    any recommended? Otherwise i'll just go with one of what was recommended previously.
    Thanx!
  17. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    There are a couple of options here.
    You can buy an external HDD caddy for about £15 to £30 and then you just put your new HDD in that and connect it via USB or Firewire so the cost isn't that much more.
    Or.
    You can get removably HDD bays that fit in your PC and then you just put the HDD in the tray and slot it into the front. On my current PC I have a full tower case, so I just fitted every bay with a removable tray and wired it up inside (the trays are about £10 each) and then when I want to add another HDD, I don't even have to take the lid off the PC. With this option, you can even have different HDDs for different reasons and swap them as you need to.
  18. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Seek time is how long it takes the disk to find a file and access it.
    Any disk that is ATA66 or better will be fast enough for video editing.
    Mark.
  19. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Regarding my question about 'seek time'- on dabs, the choices are in Ms- what's the best for me pls?
  20. Duncan Craig
    Duncan Craig
    I've just ordered another Lacie external firewire drive.
    The new d2 model - 7200rpm/200GB with the
    new oxford chipset for £280 all in from www.cwonline.com.
    I'll let you know how it runs once it arrive, no doubt it will be faultless like all Lacie gear, well worth the extra £'s.
    (The next day)
    It's here, and it's very nice, the best external drive I've ever seen.
    Made of aluminium, a small, quiet fan inside and an external PSU with a power light, medium length 6pin-6pin firewire cable. Comes with a detatchable aluminium foot so it will stand on it's end, it's very small and sturdy. 2 firewire ports, and a nice blue neon activity light.
    A quick 15 minute test capture from a camera to my iBook showed no dropped frames on capture or playback! That's with the camera looped through the drive (cos the iBook only has one firewire port)
    I'm a happy bunny.
  21. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Going back to my previous question about 'Seek time' can some one advise me what value i should go for?
    Also, i'm a bit confused regarding the interface. On dabs, there are quite a few different choices.
    I have a year old PC with what my manual calls ' UDMA--133'
    Is this what my second drive should be, or is it not important which one i get? are there better types?
  22. Duncan Craig
    Duncan Craig
    I've got two of the LaCie d2 200 GB drives now, running really well.
    Producing a 3hr video every month for worldwide publication, shooting it myself, all around Europe.
    I would recommend these drive very highly, because of size, build quality, and the fact they deliver DV video very well, they use the oxford 911 chipset I believe which is supposed to be the best.
    £280 each all in, from www.cwonline.co.uk
    The PSU's accept any electrical input and come with European and U.K. connectors.
  23. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Duncan, its the price thats causing me to lean towards internal drives....if i had the money, i probably would get one like that
    Can anyone answer my queries?
  24. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Seek time is not too important as largewr drives tend to have a slower seek time.
    UDMA-133 is basically the speed at which data is transfered from the drive - PC - drive. anything above DMA-66 is good enough for DV editing. This basically means ALL modern HDD. DMA is the speed rating of the interface on both the PC and the drive.
    Mark.
  25. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Thanks Mark, so which interface do i need?
  26. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Any modern IDE disk will do the job.
    Mark.
  27. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    so Mark, basically i can get any interface, as listed in Dabs?
  28. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    The IDE interface is part of the motherboard of your PC.
    You will be able to connect 4 IDE devices. This is any hard disks CD-(R/W), DVD-(R/W) etc.
    If you already have 4 devices on the PC then you can add a PCI IDE interface card to the PC and plug another 4 devices onto that. Otherwise just use the onboard IDE.
    Mark.
  29. scott69
    scott69
    Hi Eee-Tee,
    Just to let you know that I ordered an Internal Drive ( Seagate Barracuda - 80GB) and installed it without any problems.
    I'm about to put all my video footage on to it....
    I bought it from E-buyer for £72. ( free del over easter)
  30. Bexlee
    Bexlee
    Apr 25, 2003
    95
    South Yorkshire
    An valuable thread for me, as someone setting up in the home dv capture/ editing/ production lark.
    From what I have read here I think I will do as scott69- the offer lasts until 1 May.
    So could someone please tell me, if as stated in my Dell Dimension Reference Guide: 'The ATA-66 controller card supports ATA-66 UDMA hard-disk drives...' does that then mean a Seagate Barracuda ATA IV with ATA-100 would not be supported?
    If not, what do I need to support it, and where can I get it from?
