External Drive Cases
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Feb 2, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi all,
    I'm looking for an external drive case that houses 1 x 3.5" and 1 x 5.25" bays. Needs to be able to connect to a laptop via USB.
    Do any of these exist ?
    Thanks,
    Richie.
  2. Derek22
    Derek22
    Jan 25, 2005
    246
    +18
    have a look at this and see if it will do what you want
    its usb 2 only but seems to based around 5 1/4 inch bays but says you can fit 3.5 inch drives if you use a removable 5 1/4 rack. depending on the amount of mod you want to make you may be able to fasion some brackets or purchase some that convert 5 1/4 to 3.5, certainly a lot of the hard disk enclosures for silencing harddisks mean you ahve to use 5 1/4 mounts.
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=81537
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi Derek,
    Thanks for that but not quite what I wanted. I was looking for something around the size of a DVD player that would fit a 3.5" and 5.25" side by side.
    Thanks again,
    Richie.
