External audio delay unit where to buy?
Discussion in 'Plasma TVs Forum' started by podlest, Sep 10, 2003.
  1. podlest
    podlest
    Hiya
    Does anyone have a link to a decent supplier of an
    "external audio delay unit"??
    At a price that not costs your shirt....
    It dosn't need to be capable of handling more than 20W as I'm just going to use it on the internal loudspeakers on my Plasma.
    (It is for solving the lip-synch problem)
    Please advise.
  2. jmack
    jmack
    beringer audio delay box from www.tmfsolutions.co.uk
    it can`t do digital though
    i think its about £120.00
  3. Joe Fernand
    Joe Fernand
    Novice Member AVForums Sponsor
    Jan 20, 2002
    26,749
    The Borders
    +3,086
    Podlest
    There are a couple of 'Home Cinema' Audio delay boxes on the way - though you'll need to sit tight for a few more weeks as the two units I known of are both in final testing.
    The audio delay (Analogue or Digital) will be on the input side of your amp not the speaker outputs - you'll either plug your audio source into the delay and then the delay into your amp as a source or use the Tape or Pre amp loop on your amp to loop your selected source via the Audio delay.
    Best regards
    Joe
