External 2.5 drive
Discussion in 'Xbox Forums' started by funkyspider, Jan 18, 2008.
  1. funkyspider
    funkyspider
    Jun 7, 2007
    3,276
    Morecambe
    +491
    Does the USB port on the 360 give sufficient power to use an external 2.5inch laptop drive without additional psu.
    If so can anyone recommend an external 2.5 enclosure which is reliable etc.
    Oh and as an aside, is it possible to partition an external drive and have a FAT32 and a Mac format HFS+ partition. The idea being I can keep some HD movies on HFS partition and still be able to swap the drive around various PC's and use the FAT32 partition for other stuff.
    Martin.
  2. djstu_d
    djstu_d
    Oct 26, 2007
    486
    46
    +194
    hey, can't answer the technical bit from your post, but drive wise, i use a freecom 2.5 and have no probs using it with my box. power taken via the usb :thumbsup:
    hth
  3. funkyspider
    funkyspider
    Jun 7, 2007
    3,276
    Morecambe
    +491
    Cheers mate, thats the main thing I wanted to know. I have to be careful when buying as I've noticed some sneaky 2.5 external enclosures have 2xUSB connections needed so they get enough power.
