extending tv ariel cable.
Discussion in 'Cables & Switches' started by schmeegle, Jun 16, 2005.
  1. schmeegle
    schmeegle
    I need to extend my tv ariel cable by about 2-3 meters. Does anyone know of anywhere that would do a custom length of high quality cable?
    Also, would a cable of this length be subject to signal loss and so need a booster at some point in the process?
    Aside from this, the TV is being moved to a bay window and so any cables out the back may be more visible than if it was just stuffed in a corner. I was thinkin about cutting some holes in a nice box (bear with me) so there would be enough hole for wires going in, a seperate one for wires going out and any excess would be in the box. Anyone have a better idea?
  2. schmeegle
    schmeegle
    loadsofleads.com has exactly what I'm after. Picked up a link from another post here.
    Still interested in anyone's views of tidying up the cables tho...
