Extending Speaker Cables
Discussion in 'Cables & Switches' started by marshy.dave, Feb 18, 2003.
  1. marshy.dave
    marshy.dave
    All,
    I am in the market for a new TV and have been looking at the Toshiba 50WT29B, but before i can purchase this tv or any other rear projection TV i need to move my amp from underneath my current TV to the side.
    Now to my problem, I am currently using Cable Talk biwire cable at £5 per meter and have approx 60ft of the stuff running from my rear speakers to my AMP and the cable will not reach my AMP if I move it. Is it possible to attach more cable to the existing cable or will this cause me problems?
    I would love to know if anyone has any other ideas as pulling the carpet up and buying a new run of cable is not an option.
    Thanks,
    Dave....
  2. shodan
    shodan
    Dec 11, 2001
    10,190
    shoeburyness
    +4,526
    Add extension speaker cable between where the amp and where the start of the cable is now. The bit that goes to the amp.
    Hope this helps....
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    though id suggest a bite on the bullet and getting a full length wouldnt be the worst idea!
    ad
