Extending Sky+ cable?
Discussion in 'Sky Digital TV Forum' started by rickyjohn, Mar 27, 2006.
  1. rickyjohn
    rickyjohn
    Feb 20, 2006
    441
    28
    +23
    Hi, posted this in the cables section but thought it worth while getting some Sky experts opinion too!!
    Just got a new 42" plasma that I'm gonna be wall mounting. To do that though I'm going to have to move my Sky+ receiver 4 or 5 foot but the satellite cable from the dish won't extend that far. Can I buy connectors/extra cable to extend the length the 5 foot I require, or will this degrade the signal quality (I want to obviously ensure the PQ on my new plasma is top notch!!
    Cheers.
  2. malsat
    malsat
    Sep 13, 2004
    309
    +12
    you need a couple of barrel connectors and 4 f connectors m8 and it shouldnt lower the signal by much
  3. rickyjohn
    rickyjohn
    Feb 20, 2006
    441
    28
    +23
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
  5. coggs
    coggs
    Apr 2, 2005
    83
    +5
    I had the same problem a couple of weeks ago, found a guy selling the cable on ebay, so much per metre with the connectors on either end, it worked a treat.
  6. Mr_Mojo_Risin
    Mr_Mojo_Risin
    Mar 28, 2006
    513
    3
    2
    All Over
    +278
    :thumbsup: Or you could nip to your nearest B&Q, they stock everything you need.
  7. croissant
    croissant
    HI
    I have the same issue. Again I have no knowledge in this area. When I looked at the picture of the cable it struck me that there is only one cable. My sky+ box receives a 'dual cable?'. So do i need two kits or is it all included?
  8. JayCee
    JayCee
    Jan 20, 2004
    23,758
    Lanarkshire
    +2,570
    You need two.
  9. highet
    highet
    if you have a screwfix near you you can pick up all the bits you need there for pennies eg pack of 10 f plugs - 90p, pack of 10 f to f connectors £2.15 and all you then need is some decent coax cable and your done
    there's a section on the satcure website showing how to fit the connectors including a downloadable video
