Extending power cable on Sony KDL37EX403U? Help!
jamiev
hi, i am just wall mounting my tv and noticed the cable does not seem to detach from the unit as i wanted to replace it with a 3 metre power cable.
Anyone help?
Can the cable detach and if not how can i extend it so it will hide nicely in some small trunking and reach to the plug socket (approx 3 metre's).
thanks all
Chronoptimist
If you can't move a socket to go behind the TV, and an extension would be visible if you just added one to the end of the cable, the best option might be to buy a 3m extension, bundle up the attached power cable behind the TV and plug in the extension right behind it.
jamiev
ok, thanks, that is what i will have to do.
bit of a pain though!
if i did interfere with the existing cable or cut the plug off, then this would in-validate my warranty.
thanks again
PhilipL
thanks again
It wouldn't affect the warranty. Even the instruction manual probably has a page or two devoted to how to change or wire the plug.
Regards
Phil
