Extending Dish to Receiver Cables
Discussion in 'Satellite TV, Sky TV & FreeSat' started by windfall, Sep 9, 2004.
  1. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Hey Chaps
    Just having a big clear up and in purchasing my new rack I have found that the cables laid by Sky are now not long enough to reach the new location of the digibox.
    Is it ok to extend these (I need about another 6 feet not too much) and if so what is the best way? Should I terminate the existing cables with normal aerial adaptors or purchase the correct "satellite" type connectors and apply the same on the end that goes into the dish?
    If anyone can answer quick like I would appreciate it as I can pop out and get some more co-ax and sort this out before her indoors gets back!
    Also with regards to routing power and coax should I use seperate conduit for this? I plan to relay the aerial and sky coax in one conduit and all the power in another is this gonna be ok?
    Tone
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Extend the cables using F type barrels, i.e. use the existing f type connectors on your cables obtain two new extension cables and use the f type barrel to join them, the signal loss done correctly this way is 4/5th's of bugger all.....
    It is always good practise to separate mains and RF cables as much as possible, never bung them down the same conduit as that is technically against the wiring regs not to mention likely to give interference issues if everything else isn't perfect.
  3. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
