I have a BT Master Socket which needs to stay where it is, but I need to extend this about 60m away.
What has been done, is a normal cable (BT to RJ11) has been cut. The BT plug part plugged into the master socket and on the other end, two wires have been joined onto a Cat 5 Cable via a junction box)
The blue and white of blue pair were used.
The Cat 5 cable runs all the way to another BT socket 60m away, and the blue and white of blue pair are plugged into 2 and 5 on the BT socket.
No dial tone!
Qu: Do I need a MODTAP for this type of connection?
Qu: The BT Cable to RJ11 cable has 4 wires in it. Does it make a difference which two are used?
THE BT MAIN CABLE that goes into the BT Master Socket uses the BLACK and GREEN cable.
Please help
No dial tone!
Please help
