extending bi-amp speaker wire - please help a newbie
Discussion in 'Cables & Switches' started by gazza43, May 27, 2005.
  1. gazza43
    gazza43
    Hi!
    I have bought a Panasonic sc-pm39d which has bi-amp speaker wires;
    these are only 2m long and I want to extend the wiring to set the speakers further apart.( the wires are copper and silver coloured inside a transparent sheath )
    Can someone please tell me where to buy extra quality cable and also what type of good quality connectors I can buy so as to disconnect the extra wire if necessary and use the original length.
    ( I cant get into the speakers to just replace the existing wiring - Panasonic said dont do it!)
    thanks
