Extending Arcam irDock serial control cable?
Damian1978
Hi chaps.
Getting ready to setup the Arcam irDock.
From where it needs to sit the control cable won't be long enough. Can this be extended is it a standard type of cable I can buy longer off eBay?
Thanks all
mattneighbour
A straight through male-female cable with all pins connected, NOT a crossover cable, will do the trick.
Regards,
Matt
Damian1978
Thanks for that.
Will check out eBay :)
