Extended Media box cable for Pio 434HDE
Discussion in 'Plasma TVs Forum' started by leedsfireman, Jun 7, 2005.
  1. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Does any body know where I can get an extended cable that connects the plasma to the media box for a Pio 434HDE.
  2. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Any one?
  3. ikon66
    ikon66
    Mar 22, 2005
    444
    Tyne & Wear
    +5
    I am sure you can buy them but they are about £250 i think, have you tried a search?
  4. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    The cheapest option is to buy a Sharp one, as these are made by the same people as the Pioneer ones, but they are different length at 7m. If you are going up-market than the wireworld options are top notch from 2m to 12m:
    http://www.hificables.co.uk/ProductDetails/mcs/productID/11185
    The extra length Pioneer OEM only comes at 10m:
    http://www.multizonedvd.co.uk/acata...AH03_10m_extension_for_media_receiver_90.html
    (Although there is a very expensive optical version, I think 30m)
    http://www.multizonedvd.co.uk/acata...neer_PDA_H04WL_30m_Optical_ext__Cable_91.html
    Regards,
  5. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Am I right in thinking that one cable is a DVI-D & the other is a DFP cable. Can I just buy to desent seperate longer cables to do the job?
    Thanks.
  6. neilball
    neilball
    Jan 7, 2005
    2,748
    Scottish Borders
    +574
    Re. just getting higher spec longer cables - probably not. I was speaking to someone from The Chord Company who has been testing longer HDMI/DVI cables and found results very poor over 15m.
    Over that length it looks likely that the only option will be expensive elctrical-optical>fibre optic cable>optical-electrical interfaces as is used by Sim2 with some of their high end projectors and now Pioneer with their 30m cable. Try googling for PDA-H04 for prices - best I've seen so far was a web deal from Superfi for £589.95
  7. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    The length i'm after is about 5-7m, I was just woundering if they are just normal connecting cables.
  8. diverse
    diverse
    Jan 21, 2004
    159
    16
  9. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Cannot see any thing on Avland.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    andy JoeF can supply the cables you need at a price you like but a sharp LCD cable is the same (sharp make the media box for the pioneers)
  11. neilball
    neilball
    Jan 7, 2005
    2,748
    Scottish Borders
    +574
    If only 5-7m required then the Pioneer PDA-H02 is available for around £150. I would also recomend following Horny's advice to see how much cheaper the Sharp alternative is. If you want to try your own cables then providing you can negotiate with your retailer for a refund if it does not work then go ahead and test it out, there will be a few other Pio owners on the list that would be interested to hear how you get on :)
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,581
    The Borders
    +3,030
    Hello all
    AndyNumpty - generally your looking at a 'replacement' system cable rather than an extender.
    Pioneer offer the 10m cable - though as some folk have said it seems to be less costly from Sharp.
    The system cable is actually two cables - 1 x DVI Video cable + I x 20 pin MDR control cable.
    You can use a standard DVI cable for the Video - though be warned not all cables work; try before you install.
    The MDR cables are pretty difficult to source in the UK and some suppliers will insist you buy them bundled with a DVI cable.
    Some folk claim different grades of DVI cable will result in superior or inferior image performance and suggest you 'upgrade' the quality of the DVI cable whilst your changing cable length - I have to say I cant see much in the way of difference in DVI cables once you step up a gauge above the type of cable Pioneer supply.
    You can go to 15m and even 20m - though you have to be careful of any electrical devices close to the cable and be aware that sometimes variances in the Media Box can mean you don't get a reliable image.
    Pioneer have been offering DVI over Optical and CAT5 for a fair while now on the HDE and XDE TV's - again test everything before you bury cables in walls.
    Were working on a source for MDR cables in 3, 5, 8, 12 and 15m lengths to go with the BetterCables Display Magic cables we supply - that should give us a reasonably priced solution up to 15m without having to revert to CAT5 or Optical.
    Best regards
    Joe
  13. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,232
    38
    +3
    Hi Joe, thanks for your reply. I will be after a cable about 5m or at most 7m. Can you give me a price for a replacement?
    Andy
