Extended Battery
Discussion in 'PS Vita Forum' started by NewBeetle, Mar 25, 2006.
Tags:
  1. NewBeetle
    NewBeetle
    Oct 19, 2002
    11,552
    NW
    +3,414
    Anyone bought any of the after market PSP batteries? I Was thinking of the datel X2 one which is claiming double the regular PSP battery which seems pretty good value at £17.99
    http://www.dvd.co.uk/product.asp?id=MAXPOWERPSP
    Anyone reccomend or otherwise?
  2. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
    I have one of those from dvd.co.uk, superb battery & lasts for ages. It is quite bulky though so don't expect to be putting your PSP in any sort of case with the extended battery attatched;)
    As a side note, the first one I received from dvd.co.uk was duff, it wouldn't charge atall from new. Sent it back & the replacement worked perfect.
  3. smallmanongn
    smallmanongn
    Same thing happened to me,from the same shop as well.
  4. Tetlee
    Tetlee
    Jan 21, 2004
    20,319
    Taunton
    +4,819
    Hmm, that's strange, seems like maybe they had a bad batch. Something to think about if you're needing one in a hurry, maybe that's why they have them so cheap.
    I was a good job I tested mine as I was buying it for a long flight, only just had enough time to get it replaced.
  5. Stinja
    Stinja
    Aug 13, 2003
    12,821
    163
    +4,185
