Extend Sky Wires
Discussion in 'Sky Digital TV Forum' started by dUnKle, Sep 21, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,479
    +2,382
    Had Sky + installed awhile back but now want to move the box to the other side of the room
    The cables from the dish however are not going to be long enough
    Is there an easy way of extending both of them without removing what I already have ?
  2. applevenus
    applevenus
    You will need appropriate co-ax cable (CT-100) , 2 back-to-back f-adapters and 4 f-connectors. Easy enough to make up the cables yourself. Maplins stock that kinda stuff. Someone will jump in with the correct name for the "f-connectors" I'm sure.
  3. Fernsehman
    Fernsehman
