Extend Powr Cable - Small Connector
Discussion in 'Cables & Switches' started by ColdKilla, Aug 15, 2005.
  1. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    I have a TV with integral power lead which I need to extend. I have put the small trucking on the wall to act as a cable tidy but then when I came to run the power lead through it realised it wasn't long enough!!!
    I dont want to take out the trunking (u know that plastic sticky stuff) but want to entend the power lead so it runs nice and tidy! Is there any kind of connector I can use to join two power leads that is very small (ie will fit inside the trunking!) a lot of the connectors look quite big.
    The other alternative is to replace the whole power lead but this would involve taking the back of the sony portable - Not sure I fancy this option - is it gonna be easy?
    CK
  2. Ambient Fish
    Ambient Fish
    Apr 28, 2005
    1,640
    Wishaw
    +223
    To replace the whole power lead you do not have to remove the back of the TV set, look on the Russ Andrews web site there you will find an adapter socket which accepts the standard 3 pin kettle lead, it costs about £4.95, then have a look at the Yellow power cord and buy the appropriate length. This will not only solve your cable length problem but will also enhance the PQ by filtering out RFI.
  3. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    The power lead goes straight into the sony portable TV?
  4. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    no what he's saying is cut off the captive power lead from the back of your TV close to your TV. Then wire the remaining cable into the IEC female socket he talks about, Then purchase a standard IEC lead of sufficient length and this can be run through your conduit, plugging into the newly installed socket on the back of your TV. People putting in fancy mains leads do this all the time, but Russ Andrews is not the cheapest place in the world, so you can also try maplin.
  5. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    Ahh I see - logical really!!!
    I will just cut the power lead and refit the plug then buy a single socket extension cable - Should have thought of this myself really!
    Thanks guys,
    CK
