extend my speaker cable......???
Discussion in 'Home Cinema Speakers' started by welshguy, Jul 25, 2005.
  1. welshguy
    welshguy
    Jul 16, 2005
    20
    anyone know where I can buy some kind of connectors to extend my speaker cable for my surround sound speakers?? The wires are buried in the wall and I need to move my set up. Want something that won't significantly reduce the sound quality. Anyone know of anything or what site I can get it/them on??
  2. Timmy C
    Timmy C
    Oct 10, 2003
    4,547
    +226
  3. Troon
    Troon
    Apr 28, 2005
    151
    Seconded. A good solder joint is best, assuming you can't do industrial-strength crimping. Get as much contact as possible between the two ends, and add solder until the joint is saturated. Get some heatshrink to insulate the joints.
