Exposed Clipboard security test
Discussion in 'Desktop & Laptop Computers Forum' started by Pack Dude, Nov 8, 2003.
  1. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    Interesting....
    The fix seems to work, but like you say, I've no idea what other effects it may have.
    If you find out, maybe you could post it here? If I find anything, I'll post it.
    Cheers.
    Gary.
  3. CodeThief
    CodeThief
    May 25, 2002
    660
    UK
    +5
    Or you just use another browser (I use Mozilla) and it won't work :)
    Dave
  4. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +842
    That's quite bad. I think MS should issue a patch.
    Interesting.
  5. Beastie Boy
    Beastie Boy
    Are we all just making assumptions that because the text is displayed on the screen, then it must be available across the internet.
    Remember that when you open a web page, you download info from the remote end onto your computer, not the other way around, so in order for it to be displayed on the screen, it isnt actually being sent anywhere but remains local to your machine.
    I don't know a great deal about how browsers work so I could be wrong here.
    Cheers, Beastie.
  6. Tomfoolery
    Tomfoolery
    May 16, 2003
    148
    UK
    +10
    I'd say this is probably similar to when sites can display what is on your hard drive. The site itself can't actually view it, it's added for your machine only.
    I may be wrong but I think if sites could access your clipboard, MS would provide a fix very quickly.
  7. Beastie Boy
    Beastie Boy
    If this is the case then it is a pretty underhand way of trying to sell security software. :thumbsdow
  8. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    What Tomfoolery said is quite possible - I've seen the hard drive being displayed in a brouser, so the texy could be a similar thing.
    Gary
  9. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
    I'm not so sure that it's harmless. I imagine that the frame containing that form could be shrunk to be invisible and the form could be automatically submitted once the clipboard was pasted. The MSFN.org fix only disables scripts from using the paste function, this shouldn't affect normal scripts. Or you could just use Mozilla/Firebird/Opera/etc... ;)
  10. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,079
    UK.
    +2,571
    But what if you love Micro$?
    Gary.
  11. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +842
    Like a fool, I failed to check the second link. But since there's a security setting in IE to disable it, I don't see this as being a security problem needing a fix. Sorry for adding to any alarm.
    Nevertheless, you could argue that the setting should be disabled by default. But it is also a difficult vulnerability to exploit successfully - given the random nature of a clipboard.
