Exploding kit
dave48
I have had two pieces of equipment - an amp and my video - "blow up" on me in the last month (i.e. dead as a dodo apart from the odd humming or clicking noise when power is applied).
Anyone know what is doing this? I have all my decent kit hanging off an HMS Energia power adaptor (very high end and expensive) - and I am sure there wasn't a thunderstorm when either event happened. I am sure everything is earthed correctly and I have a surge suppressor fitted to all my aerial connections.
Should I be putting something between my mains and the HMS Energia? A surge suppressor or UPS or something? What kind of UPS can you use for this?
Help! This is getting expensive ....
Dave48
Reiner
Lightning may not be the only cause, also a surge caused by the energy supplier or even other equipment around or inside your house could be at fault.
Perhaps you need a semi-professional lightning and overvoltage protection installation, but it won't be cheap so it could be worth it in the long run.
B
Brad_Porter
I really would suggest getting your mains checked out just in case its somethig that is going to continue.
Its doesnt sound very good and I would be either inclinded to get the source problem checked out before you make really expensive purchases on surge-protecting equipment. Also, have you ruled out the fact of co-incidence of two faulty pieces of equipment that just happened to blow at the same time? I guess it pretty unlikely, but possible.
Either that, or keep some bread handy for toasting for the next time it happens.:devil: :)
