Explainition of sounds
podgey3874
What's the difference
Between
Psm
And
Cinema dsp
On Yamaha rxv371
Also standard
5ch stereo
2ch stereo
Whats best for 5.1 hd audio
An I correct in thinking standerd
dante01
Do you mean PCM? PCM (Pulse-code modulation) is for all intense purposes at the core of all digital audio. It is the language used to convey digital audio.
Pulse-code modulation - Wikipedia, the free encyclopedia
DSP is Digital Sound Processing and refers to the manipulation of digital audio.
Cinema DSP was born in 1986 and was really achieved in 1988 after Dolby Pro-Logic was released. However Dolby Pro-Logic surround channel provides a poor and weak "spot" of sound since this channel is mono. Therefore you only get a small surround soundfield, actually nothing to see with large movie theaters where many speakers are used at the surround channel. As a result yamaha engineers achieved some enhancements by using A DSP in series with the Dolby Pro-Logic decoder, that is cinema DSP, to create the type of spacious surround heard in the movie theaters. This is a seven or five speakers based system with all digital processing. All channels are stereo but this is not discrete stereo , which means that all signals remain correlated.
What is Yamaha CINEMA DSP
5ch or 7ch Stereo is a mode whereby the stereo signal is output via all speakers present. Stereo mode is what it says on the tin and only utilises the front stereo pair. If an audio format has more than just 2 channels then these are mixed down into stereo if using the stereo mode.
Yes, STRAIGHT would be the most appropriate mode to use in conjunction with the HD formats found on Blu-ray titles.
joo_9989
thanks very detailed.
Now may i ask what is neo cinema in my denon av receiver?
dante01
DTS NEO:6 is similar to Dolby Pro Logic. Both can either create pseudo surround channels not apparent in the native format or extract matrixed surround channels from stereo formats. Some prefer to use NEO:6 rather than Dolby Pro Logic and it is ultimately a matter of personal preference as to which is better than the other. Both are primarily now used in conjunction with stereo sources in order to create pseudo surround, most notably in conjunction with stereo 2 channel TV broadcasts.
podgey3874
Great thanks for the fast response
Sorry to sound stupid
What would be best set ups to set for eash of the below
Tv not hd channel
Tv hd channel
Xbmc
When listening to music via music video
And via iPhone with dock
Wilseus
Tv not hd channel - Dolby Pro Logic or DTS NEO
Tv hd channel - Standard
Xbmc - Depends what you are watching/listening to
When listening to music via music video - 2 ch stereo
And via iPhone with dock - 2 ch stereo
I have mine set up simply as:
Sky HD box - Standard Surround (in this mode my amp automatically changes between Dolby Pro-Logic and DD5.1 depending on whether it sees a stereo signal or 5.1 from my Sky box)
Blu-ray player - same as above
CD player - 2ch stereo
podgey3874
Great thanks
We're you have stated 2ch stereo would it be ok to use 5ch stereo n xbmc I would use to watch blu ray rips mainly so guessing standard for that
Is there Any other recommended settings you would suggest
Similar threads
