Explain to the builder...
Discussion in 'Home Cinema Building DIY' started by Les E, May 12, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    936
    St. Helens
    +14
    Can some one point me to a thread or post of some pictures of a Home cinema install when the sooundproofing is going in between the walls (preferbly rockwool).
    I need something to show the builder the kinda thing I am after.
    Cheers,
    Les.
  2. hatcher
    hatcher
    Hi Les,
    Got some 'architect type' diagrams I did in Visio (that I can import into Word) of my conversion - for the same reason. I don't know if they're what your looking for but if you like 'pm' me your email I'll send them to you.
    Cheers,
    Hatch
  3. aarons
    aarons
    your builder should know how to install the insulation its know different to any extension that would be built outside wall -insulation-inside wall
  4. dupontin
    dupontin
    Jun 26, 2004
    43
    Hi Les
    Check out the thread on my build... "Another home Cinema"
    I think this is the URL
    http://www.avforums.com/forums/showthread.php?t=147524
    There are a few photo's throughout, it may show u what your after ?
    Mike
  5. Jamiroquai78
    Jamiroquai78
