Explain this to me 1080i but 1366 x 768????
Discussion in 'LCD & LED LCD TVs' started by johnnyw2, Jul 31, 2005.
  1. johnnyw2
    johnnyw2
    this tv says it can display 1080i but the resolution of it is only 1366 x 768.
    I would of thought to display 1080i you would need 1920 x 1080 pixels.....i know its going to be something to do with interlacing but could someone enlighten me thanks.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    All/most fixed resolution TV's scale the picture to match the input resolution to the size & shape of the screen. It has nothing to do with interlacing but deinterlacing may also be performed since most fixed resolution TV's are inherintently progressive scan.
    -Ian
  3. johnnyw2
    johnnyw2
    so it best to wait for a true tv of displaying 1080i?
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    If you can wait that long, that is!
    You can buy them right now, but they're only available on the bigger screen sizes (45" and such).
  5. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    johnny - spend a bit more time reading other threads here - you'll see a lot of discussion about 720p vs 1080i.
    Stephen Neal seems to have the best handle on what's what, so if you see any of his posts, read and digest.
    No disrepect to some of the other members, of course.
    I'll get me coat.
  6. richard plumb
    richard plumb
    Jan 27, 2002
    14,340
    Windsor
    +1,026
    My pet question is still - how do they display 1280x720 on a 1366x768 panel? Do they still have to scale up?
    If so, doesn't it make it kind of pointless having an all digital path for best image quality, then have to scale it up by a tiny percent?
  7. jriihi
    jriihi
    Mar 6, 2005
    196
    16
    Just get TV with excellent scaling. Problem solved :) 1280x720 mentioned is 16:9.
