Explain please.....
Discussion in 'Movie Forum' started by tee, Feb 10, 2002.
  1. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    I consider myself pretty knowlegable on Home Cinema and DVD having bought my first player nearly 3 years ago but with the recent advance in technology I'm feel as though I'm being left behind.....
    I'm making the jump and investing in a new reciever (possibly the Denon AVR-3802) but a couple of terms leave me scratching my head. Could anyone explain the following please?
    What is the difference between DTS ES Discrete and Neo 6?
    What exactly is Pro Logic II?
  2. Zone
    Zone
    Jun 24, 2001
    6,736
    Barnsley
    +2,424
    Pro Logic II explained here.
    And DTS Discrete and Neo 6 explained here.
    Hope this helps?
    Si
  3. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Thanks mate, they are a help. Considering I am very lazy though, is anyone else willing to give me a down to earth, 'for-idiots' explanation?! :D
  4. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    DTS Neo 6 is DTS's algorithm for obtaining up to 6 channels of information from 2 channel sources.
    DPL2 is Dolbys algorithm for abtaining up to 5 channels of information from 2 channel sources.
    Both can be thought as developments/enhancements of plain vanilla DPL but both can be applied to stereo as well as dpl sources. I'm not sure about Neo6 but DPL2 is able to generate enhanced bandwidth differential surround information - a poor mans DD5.1!
    DTS ES discrete is DTS's encoding system for 6.1 discrete channels of information. The extra channel is for rear surround (back) speakers. It is the only true 6.1 sound format for home theatre use and ES discrete discs are backwards compatible with ES matrix decoders as well as std DTS 5.1 decoders.
  5. tee
    tee
    Sep 17, 2000
    2,711
    71
    Close by
    +50
    Ah, now I get it :) Thanks for the explanation mate, much appreciated.
