expert advice needed
Discussion in 'AV Receivers & Amplifiers' started by bishman, Jul 12, 2001.
  1. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    I am looking for a receiver and have been quite impressed by the Yamaha RXV800RDS. I was about to buy, but then I notice that both unbeatable.co.uk and empiredirect.co.uk, both sell the 1000RDS for less. Can anyone think of any reason for this.
    I have looked at Yamahas web site and the 1000RDS seems to be almost identical except for a few extra connectors and a learning remote. RSP of 799.95 and 800RDS has RSP of 649.95.
    Both the previously mentioned sites are selling the 1000RDS for under 400.00!! Is it a better receiver, or have I missed something here?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The 1000 replaces the 995 which was not available in Europe, it has 6.1 decoding and a pre-out for the center rear (to connect via external mono-block/1-channel power amp).
    Though the 800 claims to have 6.1 decoding it is only a 5.1 amp, i.e. 5 internal amplifiers and it does not have a pre-out.
    No idea why the 1000 should be cheaper, but at GPB400 it looks like a bargain to me.
    Detailed specs with panel views of the Yamaha amps:
    http://www.yamaha.com/cgi-win/webcgi.exe/DsplyModel/?gAVR00010RX-V800
    http://www.yamaha.com/menuitems/panelviews/yec/RX-V1000/brxv1000_6.htm
