Experiences with Canon LV-7105 and Epson EMP-70?
Discussion in 'Projectors, Screens & Video Processors' started by tahustvedt, Feb 17, 2002.
  1. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    I can get a Canon LV-7105 for the same price as a Panny PT-AE100 in Norway.
    The Canon is XGA and accepts 575p. Would this be a better buy than the Panny? It's a clone of the Sanyo PLC-XW15 although the casing looks a little different.
    The Epson EMP-70 is only £200,- more expensive. It too accepts 575p according to the retailer.
    The only obvious advantage the Canon/Epson will have is the higher resolution and (probably) less screendoor. The noise level of both is considerably higher at 39db/42db respectively compared to 30db on the Panny.
