Expensive HDMI Cable
Discussion in 'TV & Multimedia via Xbox One' started by toonosaurus, Jan 28, 2014.
  1. toonosaurus
    toonosaurus
    Jul 23, 2013
    657
    Scotland, United Kingdom
    +97
    I'm getting a slight judder when watching sports etc with the XB1 HDMI pass through. Although I don't want to use the the temporary fix that is out there at minute, I was wondering would a better HDMI cable help with it? I'm using a cheapish one the now, would I get any better results with a better one?
  2. signs
    signs
    Nov 28, 2005
    21,490
    nr burton on trent
    +3,317
    No you wouldn't mate , the only difference a more expensive HDMI cable could possibly offer is build quality, meaning its less likely to break in the back of the xbox .
  3. zt1903
    zt1903
    Oct 19, 2008
    9,590
    +4,479
  4. toonosaurus
    toonosaurus
    Jul 23, 2013
    657
    +97
    Cheers for that mate, that rules out that solution then, guess I might need to wait for a fix then!
  5. zt1903
    zt1903
    Oct 19, 2008
    9,590
    +4,479
  6. The SMF
    The SMF
    Nov 7, 2009
    1,792
    +154
    i get my hdmi cables from my local poundland :D
  7. Dans1210
    Dans1210
    Mar 20, 2010
    1,792
    116
    cornwall
    +751
    apparently they are working on the issue, its not your cable so dont worry
  8. TB40
    TB40
    Feb 10, 2014
    4
    Hertford, UK
    I had the same problem as AldousSnow, so I borrowed a mates hdmi and it sorted the problem out!
  9. Dans1210
    Dans1210
    Mar 20, 2010
    1,792
    116
    cornwall
    +751
    A different hdmi cable will NOT resolve the 50hz judder on xbox one! To be clear...
  10. signs
    signs
    Nov 28, 2005
    21,490
    nr burton on trent
    +3,317
    Unless he was using a cheap "50" meter cable ! Lol
