Expensive 1 Metre Dvi Better Than A Cheap One
Discussion in 'Cables & Switches' started by RLT, Aug 13, 2005.
  1. RLT
    RLT
    Mar 28, 2005
    344
    +12
    Using a Lindy 1 metre DVI cable from PC to AE500 projector and gives excellent results...
    Would I see any improvement if I used a more expensive lead ?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    RLT
    Not necessarily; but you may see an improvement using a better DVI cable - price is not an indicator of improved quality.
    Lindy offer two (maybe three) grades of DVI cable so they obviously believe there are differences.
    I tend to favour 'oversized' DVI cables built to higher tolerances - see http://www.bettercables.com; though others argue all Digital cables will produce the same results.
    Best to organise a 'Home Loan' if you can - saves making an expensive mistake.
    Best regards
    Joe
