Question EXFAT to FAT32
Discussion in 'Computer Software & Operating Systems' started by chaz, Jul 12, 2018.
  1. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    I have a USB stick when go to format it only gives me 2 options EXFAT or NTFS but no FAT 32 is there a way I can do this please the usb is 124GB
  2. John7
    John7
    Aug 6, 2004
    2,848
    +998
    Download and install MiniAide Fat32 Formatter Home Edition 1.05. You will then be able to format to FAT32 using the software.
  3. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Many Thanks:thumbsup:
  4. maddogb
    maddogb
    Apr 11, 2009
    1,658
    63
    Cumbria
    +197
    isn't windows artificially restricted when using fat32? you might get problems using this drive later on if you take that route.
