exchange nightmare !!!!!!!
Discussion in 'General TV Discussions Forum' started by jac, Mar 9, 2003.
  1. jac
    jac
    the problem is this
    Ive got a jvc 32x25 tv which an engineer has said has a purity problem. Bottom left corner has 2 inch stain which can be seen on certain colours.
    Sound and vision ,Bolton have said i can exchange it for another tv.
    I would get another 32x25 100hz but the processing lets it down on fast moving scenes and when its switched off it looks blurry.
    After searching this site i just dont know what to exchange it for.
    I was thinking of Toshiba 32zd26 but after seeing it in the shops in any mode , the picture looked crap, all text had jagged edges and the picture looked very grainy and blocky. I know they are all linked to the same signal but every shop i tried this set was pretty bad. The wife doesnt like the cabinet either so i think thats off the list.
    next comes the sony fx66 , now we both like the look of this set but it seems sonys come with an annoying buzz.
    the phillips p+ sets are off the list , their processing has more faults than my jvc.
    anyone out there got a 100hz nicam 32 inch set that they can recommend with a good picture and processing.
    thanks jac
  2. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,762
    Babel Sensurround
    +207
    [QUOTEnext comes the sony fx66 , now we both like the look of this set but it seems sonys come with an annoying buzz.
    [/B][/QUOTE]
    you have answered your own question i think by the way i have one of the the NON buzzing sony fx66 and think it is a good tv.
    hth
    regards
    Tom Barr.
  3. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    Which stand would you get with the fx66, closed (1 shelf) or open (2 shelves?).
    I think the ZD stand is great. A lot less dusting to do and it hides all ugly cables and extension leads from view.
    Also the ZD has the Hz setting and the fx66 is stuck in 100Hz.:boring: If you want to check the pic quality of the tosh look at a ZT digital picture. It shows what it can do with a digital signal.
  4. jac
    jac
    tombarr
    thanks for reply. it seems if we opted for the fx66 it would be 50/50 that it buzzed and would also have to be exchanged.
    topmba
    i like the two shelf stands as i need to put a centre speaker on top of my dvd player. they are 7 inches high, it seems a bit tight in the toshiba cabinet. could you tell me how high the two shelves are please?
    I have not seen the toshiba with a digital signal yet . I'll have a look for it.
    thanks jac
