Excel question
Mr_Wistles
Morning dudes and duddetes. I have an Excel problem that has got me stumped.
I have a list of cells which contain names (forename and surname) and a code number. I need to split this into three separate cells but I am unsure how to do it as the names are different lengths. Normally I would just use text to columns but the source data does not have a delimiter in it.
Mr_Wistles
James Smith 12345678910
Abe Christianson 549753120
A dreadful extract but it apparently the best I can be given.
Mr_Wistles
I have been trying all combinations of LEFT, RIGHT, BLANK etc. for the past 30 mins. In the end all it took was five mouse clicks!
FruitBat
Watch out for any exceptions (e.g. Arthur Conan Doyle). If there are any, you should be able to pick them up and correct manually.
Stinja
I propose a duel to settle this!
Pivot tables at dawn!
You could knock up some VBA, and assume any multi names will be surnames to cut down the number of instances, by say putting in a hypen, then run space delimiter, then take out the hypens?
imightbewrong
Any place any time.
Depends what the requirement is - you could easily add a formula column to pull the code into a single column for instance.
