Excel help!
Discussion in 'General Chat' started by spidermanalf, Jan 17, 2008.
  1. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    OK, I have tried googling, and cannot find anything.
    I am trying to add up times, they are in teh format of
    hour:minutes:seconds.
    I am trying to add them all up, but cannot seem to do so.
    I know I may have to add hours: onto the ones with just minutes and seconds on.
    Can anyone help?
    Thanks in advance!
  2. Kristian
    Kristian
    Oct 1, 2002
    2,249
    83
    Sunny Scunny
    +446
    Have you searched the Excel help for adding/summing times?
  3. Kristian
    Kristian
    Oct 1, 2002
    2,249
    83
    Sunny Scunny
    +446
    You have leading spaces in each cell. Remove the spaces and use the usual SUM(cell1:cell2) formula.
    Kris.
  4. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    Excellent thanks KrisLee, seems to work, now only to delete the first space, and add 0: to all the one without hours, on about 1500 lines of data, then repeat 15times.
    Least I will be busy tomorrow!
  5. Kristian
    Kristian
    Oct 1, 2002
    2,249
    83
    Sunny Scunny
    +446
    No problem.
    To remove the leading spaces you could try selecting the cells/rows/columns and doing a find/replace. Put a space (or two) in the find, nothing in the replace, and select replace all.
    To add the leading 0's you could try concatenating ('&' I think) the '0' with the cell in question (e.g. in cell c1 put ='0' & A:1) into another column/row and then cut and paste into the original cell. This formula/rule could be then dragged/copied down to cover all the necessary cells. The help should tell you all about this.
    I'm not that good with Excel so there may be a better/easier method.
    Regards,
    Kris.
