Excel Help
Discussion in 'General Chat' started by Tardis, Jun 21, 2005.
  1. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    Help please,
    I have just noticed that my Text Bar (I think it’s called) is missing from the top of my worksheet in Excel.
    What I’m referring to sits below the toolbars, but above the worksheet. So for example, if you click in a cell that has Text, numbers or whatever it would also show in the Text bar so if you wanted to add or remove anything in that cell you can place the cursor where in the text you wish to add or remove things. I hope this made sense?
    Could somebody tell me how to get this back up on screen please?
    TIA
    Tardis
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    View -> Formula Bar
  3. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    :thumbsup: Cheers Rich.
    That was nice and quick. :smashin:
  4. Dr Diversity
    Dr Diversity
    Another way is to right-click in the tool bar area then select / delselect from the list that appears
