Excel help
Discussion in 'General Chat' started by lostinspace, Sep 6, 2012.
  1. lostinspace
    lostinspace
    Apr 30, 2004
    1,959
    116
    +738
    I thought I was fairly good with excel but can't work out what I'm doing wrong. I think I'm missing something obvious.
    It's based around 2 columns in my spreadsheet.
    Column 1 lists the month a client contacted me- every January contact has "Jan" in the cell, February contacts have "Feb" in the cell etc.
    I can count how many contacts I have in each month.
    Column 2 may contain anything (date usually) or be blank.
    I need to count how many cells in column 2 contain an entry (of any kind) for each month.
    I can count how many cells have a value for the whole of column 2, but not when linked to what's in column 1.
    Different months have different numbers of contacts.
    Eternal thanks to anyone who can give me back my sanity.:lease:
  2. imightbewrong
    imightbewrong
    Dec 6, 2005
    53,517
    167
    Romford-ish
    +34,173
    could use COUNTIFS for this. First column as criteria column 1, criteria 1 as "Jan", second column as criteria column 2, criteria 2 as "<>" (for 'not blank')
    Actually criteria 1 should be a cell with Jan in, then have a 12-row column Jan, Feb etc and drag the forumla down.
  3. mikenw
    mikenw
    Aug 29, 2006
    319
    28
    +28
    Either set up cells with jan, feb on another tab etc , and use countif on the whole range of your records.
    Or pivot it, with a count on date
  4. lostinspace
    lostinspace
    Apr 30, 2004
    1,959
    116
    +738
    Thanks mate- I feel a right nob now!
    I was using "*" not "<>".
    I need to lay down now.
    I'll buy you a pint next time I see you.
  5. imightbewrong
    imightbewrong
    Dec 6, 2005
    53,517
    167
    Romford-ish
    +34,173
    Any time - mine's a Poacher's Choice if they have it :)
