Exact depth of a PWD6 with a fixed wall mount bracket
Discussion in 'Home Cinema Buying & Building' started by Alexg, Mar 22, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Could someone measure the exact distance from the wall to the front of the screen on a panny pwd6/7 mounted with a fixed wall mount bracket (non tilting)
  2. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    flat wall bracket on my pw6 to front of panel 4 and 1/4 inches
  3. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Thankyou very much.
    What make bracket is that?
  4. Pete58
    Pete58
    I have a Unicol bracket fitted to my PW6 with spacers and the distance is 4.5 inches. The spacers consist of 4 washers to each bolt to prevent damage to the back cover
