R
Reffolds
I have just bought an EX75 and am struggling with recording.
1. I keep losing the beginning & / ending of programmes. This never seemed to be a problem with my vhs & videoplus. I don't want to add on extra padding time since then I lose a program following on at the end of a recording.
2. I can't get series record to work. For example, I select Dr Who and set it to record every Saturday. BBC in its wisdom changes the start / end time. When I check the guide it doesn't indicate that the new timing will be recorded. If I edit the timer details, it then shows it will record. It seems to me that timer record only takes note of the start end times, not the title. Is there anyway to get it to follow the title instead & adjust times? Another example is that there was no Gardeners World on Friday because of Snooker coverage. But I had a recording labelled Gardeners World. The wife wasn't too pleased when she tried to watch it and all it had was snooker.
I can't believe Panasonic mean it to work like this so am I doing something wrong?
