EX speaker placement
Discussion in 'Home Cinema Speakers' started by StephenR, Mar 5, 2001.
  1. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Everything I've read about placing speakers for Dolby Digital EX and DTS ES tells you to put two dipole speakers at the sides of the listening position and two regular speakers behind. But what if you don't have dipoles? Is it best to put the four rear speakers in a line behind the listening position, or perhaps have the rear left and rear right speakers a bit further forward and pointing in a little?
    I'm a bit confused as to whether it is even possible to obtain a good EX/ES effect without using dipoles, so any advice would be much appreciated.
  2. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    Regardless of the type speakers, the back rears should ideally be place high up on the rear wall. In a EX setup the rears should be placed on the side walls slightly ahead of the listening position. As for type of rear speakers, THX specify dipoles for rears and back rears. I have bipoles as rears and monopoles as back rears and while I have nothing to compare them to, for me it works very well.
  3. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    Stephen,
    It stands to reason that to get the sound to 'wrap around' you will need to have the 4 rear speakers on different planes. I have used dipoles for 5.1 only and was quite happy with that.
    Now, I'm using 4 direct speakers in a 6.1 set up and it is awesome.
    However, as with all things with speakers, you should experiment as much as practical with positioning and settle on what you like the sound of best.
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,276
    A couple of useful pointers. Use two rears even with a 6.1 set up. What you need to avoid is the rears being in the same plane / line as the centre. I.e you need to set up a triangle between the centre and rears, otherwise it is difficult to work out where the sound is coming from. This may sound daft but it is true, honest.
    I have chosen the dipole route personally. Others have used uni (mono) directional speakers. Some have used bi poles. There are lots of solution to this problem. If side wall are close dipoles may help. Uni dirrectional speakers have their supporters at the rear. Many people promote (for good reasons) di poles on the sides and unis on the rears. This I think has some merit for small UK rooms. Although I haven't done that yet (I have the capability to test one day). There is more information on this on the Tag web site, use search engine. Remember there are many solutions to this problem, you may well be happy with several of them.
  5. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Thanks for the replies. I'll probably try it out - I just wanted to make sure that dipoles weren't "required" for 6.1 sound, as I don't want to buy another two direct rear speakers and find it wasn't worth it!
  6. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Originally from the wonderful Granite City, Aberde
  7. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +70
    If you ignore the Yamaha review the diagrams and text about speaker placement make very interesting reading.
    Cheers for that Jim, just got to get the speaker up high on the wall bit past the trouble and strife though, otherwise definitely good reading
