EX, ES, and 6.1 audio and Hollywood Plus
Discussion in 'Desktop & Laptop Computers Forum' started by Bascombe, Jun 17, 2003.
  1. Bascombe
    Bascombe
    Jun 1, 2003
    122
    +4
    Hi all,
    been thinking of getting a surround system together, and am currently playing dvds on tv via a Hollywood Plus outputting svid. Now, I am for the time being entirely happy with the H+ image wise, but just suddenly wondered - will my search for the ideal affordable av ap (current candidate yamaha rxv430) hit a bit of a hurdle if the H+ can't output the newer sound formats via the spdif? I'm not too far up on the tech aspect of it all-does the H+ just send out a 'raw' digital signal, and the amp does the rest, or do both have to support the sound format??
    Any input would be most welcome :)
    Bascombe
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The H+ should output all the DD and dts formats fine. They are there to be backward compatible.
  3. Bascombe
    Bascombe
    Jun 1, 2003
    122
    +4
    Glad to hear it - its one of the better hardward purchases I've made, and I'm loathe to part with it at the mo!
    Bascombe
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Should you ever want to replace it, the current step up is the Sigma X card which can do RGB SCART and progressive component output, among other clever things.
  5. Bascombe
    Bascombe
    Jun 1, 2003
    122
    +4
    My understanding is that the H+ can also do rgb out - but you need to do all sorts of homebrew cable making. I've also seen posts that it'll put out a progressive scan signal, tho again it needs a special cable. Tv cant do progressive, but rgb out would be nice.....if I can only get to grips with the whole cable making thing:)
    Bas
