stokes2608
I've been offered a ex service pioneer lx5090 for £1700 the TV has been on display for 3 months at 10 hours a day should I be worried about that many hours on display?
How can I check how many hours the set has had on it?
You could use my freebie KuroTIME program here:
KuroTIMEsetup.exe - 4shared.com - online file sharing and storage - download
However, you really do need to use a PC with a dedicated 9 pin RS-232 port.
It does support some USB/serial adaptors but not all.
Also you need the correct serial cable to connnect to the TV. (not null modem)
Could you recommend a usb to serial adaptor that would work?
I bought one of these from this ebayer
USB 2.0 to 9 pin RS232 COM Port Serial Adapter on eBay (end time 22-Jun-10 11:18:20 BST)
Please note I have no connection with this ebayer and I can't guarantee they are selling the same adaptor that I bought.
However, it looks identical in the picture![]()
Assuming this RS232 adapter works, would you just plug the adapter into the 5090, run a USB extension cable from the adapter to a PC, then open the KuroTIMEsetup.exe program to automatically see hours ?
Sadly no...
You also need a gender changer adaptor or a serial cable with sockets at each end.
This is because Pioneer put a 9W plug connector on the back of the TV and the USB/serial adaptor is also a plug.
So you need a 9 way skt/skt serial adaptor. (AKA gender changer)
Just to complicate things, you need to avoid NULL MODEM cables as these appear to be exactly what you need (SKT to SKT cable) but they have a pin swap on pins 2 and 3 so this type of cable won't work.
Thanks for the info Chelsea Fan.
OK, so thats a serial cable (skt/skt) from the USB/Serial adapter (plugged into the PC) straight to the back of the 5090 ! Then, run the Kuro.exe program......
Can I assume that the KuroTIME program does not put a "flag" on the 5090's eeprom to show that the service menu has been accessed and therefore invalidates any outstanding warranty.
It doesn't need to access service mode to get this data
There's a whole load of RS-232 commands that can be sent to the TV without needing service mode including the ISFccc interface. You can also control the TV as if you were using the remote control. i.e. call up the usual onscreen menus and change channel or volume etc etc. The info to do all this is on the Pioneer website.
Service mode access requires a separate command and this unlocks loads more commands but no one really needs access to these.
The only possible exception is the grey sidemask control for 4:3 content. In order to change these to black you need to access service mode first.
I haven't released any freebie programs to allow sidebar adjustment for that very reason. i.e. the TV has to be put in service mode first.
I'm not convinced the warranty would be automatically invalidated anyway and I would be more concerned that people would want to explore service mode and end up adjusting stuff that should be left alone.
Could you provide a link to this please.
how do you do a bleep test with the 9 pin cable
